Most neg camber on the Spax RSX kit
Hi, My clio already came fitted with the spax RSX kit (rear coilover setup). I understand the bolt holes are elongated to allow you to adjust the camber. What is the maximum amount of negative camber you can get from the elongated holes?
Does anyone know any decent suspension setup places near North Lincolnshire, the car is 90% track use.
Managed to max the passenger side out at 3degree, came to drive side and it maxes at 2.5 so I need to elongate the hole a bit if I want some more adjustment.
Both set to -2.5 for now.
