Mot fail advice...
RichieJA
SCAMMER !!!!
Car  clio 172
Can someone help me with which parts I need for my mot ???
And advise me on how hard the job will be or estimate cost at garage
Steering arm has relative movement in both its fixings (both)
Anti roll bar has excessive play in a pin\bush nearside front
My guess is you'll want a tie rod, track rod end and an anti roll bar bush.
As for part prices my guesses would be:
tie/track rod - £25
TRE - £15
Anti roll bar bushes - £15
Cost of fitting - if you don't have a tool suitable for undoing the tie rod then it's probably going to be easier (and maybe cheaper) to go to a garage, I'd say about 2 hours labour to be safe, then you'll want the alignment doing.
If you can do it all yourself then budget £100 inc alignment, £200 if you take it to a garage (maybe more depending on parts prices)
On eBay the parts are £46 local garage that done mot are 20 a hour labour is not so bad
