Adey.
thats very true but if that were the case you wouldnt drive from swindon to tewks to waste some money on seeing what it does on a dyno if you didnt care what hp it makes
I went down to have a go in your cars to see what they were like, as it turned out I didn't need to. Ktec 182 turbo at the moment produces 330hp that thing in 3rd and 4th gear accelerated like mine does in 2nd so if mine is around that figure I'll be very happythats very true but if that were the case you wouldnt drive from swindon to tewks to waste some money on seeing what it does on a dyno if you didnt care what hp it makes![]()
news to me, id of let you take it out if i knew. ok quick question, then ill leave the thread to run, if your new build only comes out with 290 bhp will you be happy with it?
Well if I'm not happy I'll go to power station RR then I'll be happy!!!
lol but figures arnt what your looking for. catch you at the drag or track sometime
No disrespect to anyone but I listen to the tuning companies no one else
I took mine up to TDF to see if they could improve the map that Ktec done for me,I didn't have a problem with the map that they did but I just curious to see if it could be improved. After a couple of runs on there RR they told me it was spot on and they couldn't better it and that's coming from one of the best mappers in the uk!!!!mistake no.1
if you want good power, and better economy, get it mapped by someone who knows what they doing.
on a more serious note tho. thats the 1st time iv EVER heard a tuner say that their map isnt better than ktecs...if thats the case id run away.....very quickly ....from the tuner that said it tbh.
And Ktec had locked the ecu......![]()
use another ecu then. im sure there are other mappers that could map it tho if you used that.
Yes the ecu was locked, TDF does it to there's as well! But it still went on there RR and they checked how it was running as it turned out it was spot on that's why it's back at Ktec having more work done to it. If it was not running correctly it would not be at Ktec now!! Trust me if ktec sc kit was crap I would be the first one to **** it off, but its been 100% reliable no problems at all so what can I say!! I'm giving you info on what I have done and not info from someone who knows someones friends brothers etc that knows f**k all. And as for the gripper diff I'm getting fitted they are a fit and
forget item an oil change takes 20 minutes to do every year or so!!!!!
Does the Gen90 even work properly yet
:S sounds wrong to me. Sure if you change the oil regularily then it will improve longevity, but you'll still need the plates replacing.
