Mud Flaps ?
Steve
Car  LMC10, Puma E
Good or bad idea, thinking probably good idea.
They protect sills & lower doors & probably keep the road grime down on sides & rear?
Not mudflaps as such but I run small Kaylan stone guards up front to save a lot of rash down the side of the car. They can barely be seen most of the time.
Very nice.
Been looking at the standard factory ones but came across a video for rally flapz ?
Rally Flaps FTW!
Wife says grow up & just put the standard ones on it 🤦‍♂️
After searching they do make them for the ST but you cannot find them from the accessories site, if you build a car you can add them & that’s where I got the serial numbers from.
  • Haha
Reactions: GiT
Hi Frayz, do you have a link for where to buy these and the tape you used please?
They're these but not PVC. The seller makes flaps from high grade Kaylan too of which they will make you a bespoke set, you just have to message them and ask.
Tape for the top is just 3M body tape, as used for reapplying vehicle trim, badges, mouldings etc. :)
Never understood why Renault didn't offer them as an OEM option on the RS models. The bottom picture is subtle and they perform an actual job.
I'd buy a set today, if they came straight off the shelf.
Renault missed a trick never making proper RS mudflaps
The ones on the Megane are nice and subtle, they only fit because the normal Meganer has the same wings and skirts though
