My 172 Cup exploded!!!
  FTO GPX Mivec
Hey guys sorry if its in the wrong section but need advice....
On way home tonight under normal driving conditions on a typical b road I experienced a very loud bang/explosion from the front of the car followed by the cabin filling up instantly with black smoke, dash lighting up and power loss, so pulled over asap and turn car off called aa for assistance. was doing 50-60 at the time, scared the s**t out of me.
Eventually got picked up, massive oil leak on road under engine, visual inspection of engine with torch in dark shows nothing on top of the engine bay or any visible damage, but engine compartment is sodden with oil.
The Dash reports no problems, done the system diag check and that is clear, car restarted once but massive vibrations coming from engine so shut down no more than 3 secs. running.
Had an early FULL 72k service performed in april with cam and aux belt replaced so wouldnt have thought it would have been a belt snap.
Oil and water levels normal and engine temp was fine, typical operating temp whilst driving.
Any ideas what mechanically may have happened????
My second question is, I purchased the car from a local dealership at the very end of December 06 part of the deal came with a 4* WMS warranty,
In the morning, I'm going to try and claim on that warranty, if the dealership fights this, how do i stand from a legal point of view? car has had all services and mots and no reported faults ever, I have full paper work. Can i leagally claim a full refund, partial refund, like for like exchange or what?
Any advice would be appreciated, I have heard the terms 'not fit for purpose' used before is this something i should look to investigate?
cheers for your time, Im totally gutted!
PS car has only done 56k 02plate
Geoff
  Clio 172 Sport Ph2
Sounds a bit like a conrod has made a bid for freedom out the side of your engine mate!!!
  FTO GPX Mivec
Im sorry you have to forgive me im not mechanically minded, but the codrod idea would seem to suggest that its a complete engine replacement?
that depends on whether the malfuntion has damaged both the top and the bottom end of your engine...i suspect that you will only have to replace the top...
the very same thing happened to my friends celica...
Sounds like bottom end troubles.
Possible Conrod snap, bottom end bearings complete failure or Piston crack/exploded/melted
If your cam belt had snapped it wouldn't of fired up again oh and I couldn' help but LOL for real at
  Clio 182 & Saxo VTR
Sounds like something has come loose from the bottom end. Please dont start it again, it may cost you an engine. Get it home, clean it down and see what went wrong. :)
  alien green rs133
conrod gone??? equals a dirty huge hole in side of block, would explain oil, sounds very similar to the 3 conrods that have jumped out of bed in the rally car, new block and possible head damage
  lift number 1 @ btm
i'm sorry to say, from experience. if you have thrown a rod, you can expect to buy a lot of new valves. and get a bill in excess of 2k!
Connecting rod. connects the piston to the crank.
Top end of it is where the small end bearing is and a gudgeon pin connects through the piston and into the top.
The bottom part is where the big end shell bearings go.
  MY10 R35 GTR
sounds expensive tbh.
Very much like a conrod, so valves will be in order, conrod etc. But if has gone at 72k, id be suspicious of the others.
Cookie
aaah i see... lol
Here's a picture of one
Not the sort of thing you want escaping from your engine at high speed :p
  FTO GPX Mivec
thing is it only just done 56k, i put it in for an early 72k (5years) in april, absolutely gutted, im now unable to get to work, so hoping warrenty will cover it.
However, something like what i have described shouldnt happen to a 5 year old car that has always been well serviced and maintained, unless thier was an underlying flaw in the engine itself from manufacture? should it?
  Clio 172 mk2
Gutted....does sound like bottom end failure
I think at the price it'll cost to fix you may be better off dropping a new engine in
  FTO GPX Mivec
Hey guys, got the car back to the dealership in which i brought it from end of last december, basicaly the bottom end of the engine left hand side got a massive hole in it, dealership said they would need to take it in to see what caused to the problem but i will be lookin at 2-4k to fix.
So 2 options really, one I see if i can claim from a legal standpoint? or just strip the car down, as everything is mint condition. and try recover some of my losses.
What do you guys reckon?
  Disco 5 ,Monaro VXR
why dont you see if you can get another engine?? if i remember right there are a few people on here that work or own breakers etc
  m-tec bmw 325 ci spo
brand new from renault is 2,995 service exchange alot of money try yozzasport they got a few spare ones knocking about or pm matt black on here
  FTO GPX Mivec
very nasty garf, even more scary when it happens on a b road which is pitch black . around 50/60mph
  FTO GPX Mivec
Subway how much you willing to pay, insides are imaculate condition. nearl valet condition as it only me that uses the car, never smoked in :) so to speak hehe
  AMV8, Mk1 Golf
was there any chocking before it happened... usally if your about to throw a rod it goes DOG DOG DOG DOG, which is faster when the revs are higher
but yes deff sounds like there is a hole in the side of the block.
  FTO GPX Mivec
Taylor, no warning nothing, car was driving normal without any reason to think anything was wrong.
  AMV8, Mk1 Golf
odd, must have just snaped, be interesting to see it,
my mate has a collection of bent valves from when his went, very impressive, and my wee brother managed to actually crack the block in half!!
pm me how much you would ask for the whole car?
  172 ph1
You have warranty though? Or does it have some very low limit?
Pick up a second-hand engine and try to get some good will from the garage that sold it to you.
