My Boot Install Process (56K No Go!)
Car  GOLF GT TDI
Some of you may have seen my last last install probably at the French Car show, I have now changed my install again here is my process.
After Months And Months of designs and thinking what to go for i have finaly finished my install.
My Old Install
THE PLAN
To Fit the following:
2 x Genesis Profile Sub Ultra's
1 x Profile Four Ultra
1 x Audio Control Epicenter
Pair Of Alpine Crossovers
1 x Optima Yellow Top Battery
The first thing was to rip out the old install and Sound Deaden.
Second Battery Holder for Boot
I will be fitting a Optima Yellow Top Battery in the boot along with a trickle charge system, it will be screwed down to this is the spare wheel compartment.
Holder fitted alone with false floor
A false floor is fitted for the subs to sit level across the wheel compartment
False Floor Part 2
This is going to be for the Crossovers and Epicenter
Test Fitting
Making Sure They Fit ok
Carpeting
Carpeted And ready to install
Amp Rack
Amp Rack For Sub Ultras (Sorry Process Pics of These)
Amps Fitted
Amps Tempory Fitted
Fitting Flooring
Fitting of Crossover and Epicenter Flooring
Fitting 3rd Amp
Fitting Of Profile Four Ultra
The Wiring
Just quickly wired in for the amps it to bet set up properly.
The Wiring Tided
Tideing The wires
I am currently running in the system then i will be getting a DB Reading:
I know its not either to everyones taste or to the standard to some peoples work on here but i have done it myself without any help so i am kinda proud :)
Comments Welcome :)
well its very well done but cant help but think the car would be much more enjoyable without all that extra weight (+ the obligatory) imo :)
thanks :) i am not quiet finished yet but most of it is done just little visual bits to do
stu i dont like subs and boom box cars that shake my windows as they go past, but that my friend is a true work of art. would love to see it up close. the carpeting looks very very good, and i so glad that, since you have decided to do it, you havent gone down the neons and plastic s**t box look!!
a big well done!!
and no Im not 40 lol ;) half that :D
jamie
looks very well done, bet the bass is amazing i saw the kicker hummer at trax and that was mental!
how come you have 3 amps and only 2 subs?
change the subs lol,
other than that good effort :D
surly though would make sense to have 4 amps 2 on each then run them parallel , bridged, one slave on master for each sub
the two bottom amps are profile sub ultra's 1000 Rms each "Genesis Ratings so about 1300 Rms actual rating" one for each sub
and then the top is a four channel amp for my components
wow man that is one amazing install i wouldnt even know where to start wiring it up, im having to research just how to wire up shelf 6x9 lol
looks amazing nice one
So how much slower is it with an extra half a ton in the boot j/k ;)
Great install tho fair play, can you see anything in your rear view mirror?
The kicker hummer is quiet Believe me :D
Check out some of the cars on Talk Audio if you want loud........
the view isnt as bad as you may think i decided to put the whole of the amp on a hinge so by simply flicking the rear seats forwards and unclipping a few bits the whole amp will fold down towards the front
I'm not a fan of filling the car with ice but i must say. well done, keep it up. There's a business venture awaiting you i'm sure.
done a good job matey, and worth being proud of it - personally though i dont understand the whole big sounds in car thing.
Final Steps
Added Deading to boot panel
once i done it i had to put all the clips back into the boot door
problem i had was the deadening, the clips didnt wanna clip in the holes fully, so i put a little bit of super glue on both the clip and the boot and held fine,
now carpeted the rest of the boot:
Before
After
Thats dam impressive fella, although my favourite part of it has to be the tidied wiring, that must have taken you ages and something i could never be bothered to do on any of my installs
the wiring took me about 3 days alone very happy with it nothing rattels now.... well from the wires n e way
agree with taylor, personal opinion id go for sumthing else. xxx if could afford it or oz matrix but looks spot on mate. long as your pleased
thanks for all the kind comments people just had the system properly set up now, when i am driving along its a little worrying when i pull into a car park and set off about 8 car alarms lol
