GOLF GT TDI
Some of you may have seen my last last install probably at the French Car show, I have now changed my install again here is my process.
After Months And Months of designs and thinking what to go for i have finaly finished my install.
My Old Install
THE PLAN
To Fit the following:
2 x Genesis Profile Sub Ultra's
1 x Profile Four Ultra
1 x Audio Control Epicenter
Pair Of Alpine Crossovers
1 x Optima Yellow Top Battery
The first thing was to rip out the old install and Sound Deaden.
Second Battery Holder for Boot
I will be fitting a Optima Yellow Top Battery in the boot along with a trickle charge system, it will be screwed down to this is the spare wheel compartment.
Holder fitted alone with false floor
A false floor is fitted for the subs to sit level across the wheel compartment
False Floor Part 2
This is going to be for the Crossovers and Epicenter
Test Fitting
Making Sure They Fit ok
Carpeting
Carpeted And ready to install
Amp Rack
Amp Rack For Sub Ultras (Sorry Process Pics of These)
Amps Fitted
Amps Tempory Fitted
Fitting Flooring
Fitting of Crossover and Epicenter Flooring
Fitting 3rd Amp
Fitting Of Profile Four Ultra
The Wiring
Just quickly wired in for the amps it to bet set up properly.
The Wiring Tided
Tideing The wires
I am currently running in the system then i will be getting a DB Reading:
I know its not either to everyones taste or to the standard to some peoples work on here but i have done it myself without any help so i am kinda proud
Comments Welcome
My Old Install
THE PLAN
False Floor Part 2
Test Fitting
Carpeting
Amp Rack
Amps Fitted
Amps Tempory Fitted
Fitting Flooring
Fitting 3rd Amp
The Wiring
The Wiring Tided
Tideing The wires
Comments Welcome
