my brakes...
Car  Clio 1.2
My brakes have decided to not work as well as they used to. my dad cant figue out why. he has replaced the rear brake pads and disks and stuff, so he thourght it could be the cambelt, but thats ok. :S
Any ideas?
kim
Pads, discs, fluids, fluid lines. Take your pick, could also be something to with your break pedal.
The cambelts to do with your engine :S
duno if i hav spelt it right or not but either way no he doesnt think so because went for a drive and tried brakes, then turned engine off and did the same and he said that it is working. whether its just tempermental i dont no. wat do you think?
all pads and disks are recently new i think, sure he replaced the front ones aswell, not sure, back definately new though
get the fluid changed and bled then. made a massive difference on my old car and it wasnt that old when it was done
yer very good point. Im not completely useless when it comes to cars really. Thanks everyone :D
Maybe a leak on the master cylinder vaccuum hose? Or the cylinder itself.....
very true. tirdness kicking in. *laughs out loud*
knew to "internet" type aswell? laughs out loud is abbreviated as "lol" all over forums and msn worldwide if you haven't yet noticed. there's loads of others too if you wana get really geeky LOL
The brakes are fine with the engine off for other reason.
Bleed the brakes then tell us what exactly the problem is does the pedal go sofr or hard or just go right to the floor with no resistance etc.
