Hello, dont really post on here much but i lurk in the background
This is a long thread as i like to explain stuff fully
I want some genuine advice though as to what i should do. Heres a few things about me, im a mk1 lad through and through, had 3 valvers and a hybrid. They have all had lots of engines making all sorts of power, but i always wanted more.
Last year, myself and Craig @ APD took a joint deal on a renault clio cup car, it had a throttle bodied F7R engine. Craig wanted the car to house his own custom F7R ITB build.
So i had a throttle bodied F7R engine and the engine currently in my hybrid. Its worth noting at this point that the engine currently in the hybrid was an unknown, it was bought from midge and supposedly a forged engine with cams e.t.c, it had an 8200rpm limiter, but only made 154bhp, so i always presumed it was actually a standardish engine.
So the time comes and my hybrid engine leaks LOADS of oil the day after FCS08, so i ripped it out the following day once and for all and stripped it over at craigs. Well.... to cut a long story short it was a fully worked engine, it had FOrged H/C pistons, forged rods, worked crank, full headwork cams e.t.c I guess it just wasnt buit very well if it didnt make the figures, its was quite quick though.
I decided this was a great opportunity to make a fresh Forged ITB F7R lump. So i set about a long project of fully rebuilding the current and putting the ITBs on it with the ITB meganne F7R head from the cup engine, the cup engine only ran a standard bottom end though, hence i thought id build a nice shiny fresh one. Using the old forged pistons from the hybrid lump with new piston rings.
The final spec came too.... (after many thousands of ££££)
- Rebuilt Meganne F7R Cylinder head, with de-lipped valves, all new stem seals and gaskets. Headwork carried out by Craig @APD (not FULLY worked though).
- Catcam GOLD uprated Springs and Retainers
- Catcam 5502320 (11.75mm x 278 degree)
- Catcam TruLock Pulleys + DTI setup
- Williams F7R bottom end, rebuilt.
- Forged H/C JE Pistons 11.2:1 CR
- Forged Rods
- ALl new gaskets and seals.
- New ACL/Glyco, main end, big end bearings, thrust bearings
- CYlinder block rehone
- New JE Proseal Piston rings (Gapped by craig @ APD)
Jenvey 45mm Parralell DCOE ITB's
90mm Air Horns
Fibreglass air filter backplate
Webber FPR
Custom fuel rail
SHort Chadil Inlet Mnaifoldm fully port matched to the cylinder head.
289cc New SIemens injectors
VEMS stanalone management system and a completely homeade loom by myself.
Custom alloy low profile radiator and compact fan.
The VEMS had a rubbish map on it from the cup car, me and a mate spent many days road mapping with a wideband trying to make it good, and we got it to a level we were happy with. It made 204bhp on a very dodgy RR and did a 13.6 at santa pod.
http://www.youtube.com/watch?v=TcXhNiEquM4
We towered up the bottom end with hashbrown and cheese
Almost there..
SO what is the point of this thread, bragging rights? to look cool? No.
THe engine is now dead, it lasted 5500 menacing miles. A very unfortunate overlooking caused complete failure. 2 bolts holding an air trumpet on worked loose and were sucked straight into Cylinder #1, the engine is now locked and will not even turn over.
I want to use the car again, and have speed but ive lost nthusiasm for it.
Im now looking at F4R engines, i can get hold of one for around £350 (172 ph2 cup engine), and slap my ITBs straight on (bar the inlet manifold id have to buy).
SO for the time being what can i expect on a cup 172 engine on a proper Jenvey ITB setup?
Talk to me about cams! The F7R has a wide choice, my cams are quite a savage spec and i loved it. But what happens to the dephaser? Do you still use the dephaser activation on standalone?
Can you get non VVT cams and catcam pulleys?
DO the F4R engines respond well to headwork?
Should i just stick to what i know best and rebuild the F7R again?
Wossner state the standard compression ratio for an F4R is 11.1:1 is that correct? THey list F4R Maxi pistons ith 13.3:1. WOuld these be good for a flat out ITB build? or would they over compress the engine?
if i were to go F4R evetually id get oversize 84mm pistons and make it 2.1
Its probably a good idea to point out ive not pulled apart the engine yet, it got towed home and its sat on the drive for the past month and a half ever since.
All help, comments, and advice welcomed.
- Forged Rods
90mm Air Horns
Webber FPR
Custom fuel rail
Almost there..
