Black mk3 clio
Thank you very much, I shall give this a go sometime in the week!Hi there! Thanks for the comment, I'll talk you through it. Basically the metal bracket is holding the bulb in place. You should remove the rubber cap which is covering the wiring. Next remove the black connector block(it has the wires coming from it) a slight pull and it should come out. Then you can unclip the metal clip carefully making sure not to drop it, then the bulb should easily pull outwards. What I would suggest is you take a picture with a flash phone to get an idea of what your looking for before you disconnect anything, that way you can also see how the replacement bulb should look when it's refitted. I would suggest using a torch too, goodluck mate.
