My Radio won't pick up FM.
Daniel
Car  Whichever has fuel
I've even tried fitting a new head unit but that doesn't work either.
Anyone had this before?? AM/MW all work fine.... :S
u need a new aerial base, which comes with new cables, i replaced one the other day, had the same problem as u!
at the bottom of the ariel base as in the rear of the cars roof? I haven't got to chase a whole new ariel lead through have i???
yer the base of ur aerial on the roof, to replace it u have to pull down the head lining, remove the 10mm nut holding the base down, disconnect aerial lead from behind o/s/r interior panel (thats where it joins to) then its will just pull out from the roof
