clio 182
ive finally made a start today after finding a garage to do the work in i stripped the whole front end ready to take the engine out next weekend
a few pics
How do you "find" a garage? lol
All these turbo clios turning up are making me more determined to save up and turbo mine!
Are you using the ED kit? If so, how much is it for the DIY kit?
Good stuff, another one to keep an eye on.
what spec are you going for?
Boost FTW.
Where in South Wales are you from?
Just pistons and rods mate and putting all new bearing in and all new gasketsWhat constitutes megane internals, is it just pistons and rods? Or does it include valvetrain etc...
Here is mine when I was building it. There are no cut outs for valves and is is not TDC. The pistons are the same overall length as the standard 172 pistons.
I'm sure someone said they will hit if you don't either adjusting the timing to compensate or cut the slots.
Will be watching closely to see how this goes! Good luck![]()
Im going to get the slots machined into the 225 pistons, I'm not taking any chances with this, south wales pistons can do that for me they are based in Cardiff so just let them sort it out![]()
Just a quick question how do you get the pipes off the heater matrix? Cheers
a quick question guys does all the wiring come away from the engineor does some come out with the engine?
with the fuse box in the engine bay obviously unplug the white plug how do you get the rest out?
Can you not get over valve clearances with a Megane head gasket??
