My window has broken, went to open it today and crunch, please help....
Car  ph quick
Got to dartford today, went to open my drivers window and crunch, the glass fell forward and its broken. Im now in london with not many tools :(
The motor seems to work still as i manages to get it closed again pulling the glass and pressing button at the same time, but when it fall forward teres a black plastic bit that would normally run insice the door frame i assume? This is broken, is this a replacement part that i can buy?
Has this happened to anyone else?
I know the regulators and the clips usually break as it happened to a friends and i helped him fix it, but this is different...
Please help if you can :S
Yeah, it was either that or ram the barrier, if id known my window would break i would have thought about it a bit more but i still think i made the right decision....
you can get the clip that goes through the hole in the glass to hold it into the rubber runner... you can get a rivet version from renault or Autoglass have some with a plastic pin which are just the same...
nice one, that sounds like what i need, do you open the window all the way to gain access to that bit of the glass inside the door?
Is there just one of these clips that slide inside the door pillar?
