rear brake cylinders are cheap matey !!....i think they are only about a tenner each !!...then it only takes about 20 mins each side to fit.......did you replace the rear drums ??....perhaps thats why the job was a bit more expensive ?..............has the brake system been bled ??.......if you go to a proper garage..i.e main dealer...you can have the system flushed & new fluid put in...that sometimes improves performance..(brake performance that is) having braided hoses fitted can improve braking....but only a bit !...............or you could opt for the brembo conversion that someone is offering for £500..includes calipers,discs & pads !!....but you need min 16" wheels to go over em !Quote: Originally posted by rich_g85 on 24 June 2003
if i said to you my brakes arent as good now as they were when i bought the car, which bit (or bits!) need replacing? im thinking either brake shoes or discs. the rear cylinders have just been replaced (at great expense).![]()
