Ph1 172
Had my ph1 172 for a few months now and finally getting round to checking in properly after joining up a few weeks ago.
Bought my 172 from gaz from this forum and it has sat unused ever since! It had a misfiring problem so i changed the usual leads, plugs, coilpack and finally the injectors, its a lot better but still a bit burbly from the exhaust.
The sump was leaking so changed that over too and fitted new exhaust mounts as well as giving it an oil/filter change.
Only mods so far are fitting my pipercross viper induction kit from my gti-6 and removing the foglights (one was cracked), replacing with stainless steel cold air feed trumpets, clear side repeaters and a shorter roof airiel (binned the fishing rod!)
The car is going to be dry/weekend use only and the odd track day so will be off the road untill march/april doing it up slowly over the winter.
Anyway hello to everyone and thanks for all the info so far.
