Need a new sump plug
  1999 Clio 1.2 8V
Hey guys,
Gave the car a good service today, unfortunately after being a left for a few hours it seems my car wet itself and is leaking oil from the sump plug.
Not sure whether its not tightened enough or the washer is fucked or whatever
But does anyone know where I can pick up a new plug and washer? Its for a mk2 ph1 1.2 8v
newbie
  1999 Clio 1.2 8V
Totally skipped my mind! Found a new plug and washer on ebay for 3.29 or something though so not a problem thankfully!
Struggler
  Ph1 track 172
you need to change the washer when you do an oil change. please remember this in future lol
  1999 Clio 1.2 8V
Hi guys, got the sump plug and washers last night.
it came with 2 washers, a copper one and a steel one with a rubber seal, which one should I use?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Is your sump cast aluminium or pressed steel? If its cast ally use the steel/rubber unit and the copper washer if not.
