Inferno 225
Just got on and have been reading that they slow the car dwn or is that a load if bs or will I need a remap wiv the viper on ?
lecky
lecky
Generic after market air filters are always terrible, they pick up hot air, and if you go through a puddle it'll gulp in water and hydraulic your engine so destroy it. Renault spend years and thousands developing the sport air box, to give best efficiency, and your going to throw a £60 piece of rubbish on. Remap won't help either, as a remap doesnt make it take in cold air, just alters air/ fuel ratio's and ignition. Put the standard one back on!
Renault spend years and thousands developing the sport air box, to give best efficiency etc.......Put the standard one back on!
Yet the Espace V6 airbox gives an improvement but they didn't use it in the clios? I get your point totally, and just think that it's french logic all over, before I get flamed.
lets keep in mind though that the ph1s did use a similar airbox and it was changed for the ph2, however the ph2 box is a little quieter making the engine a bit more efficient (apparently!!) so although the espace airbox is better for maximum power the ph2 box is a good compromise for power/economy/drivability, which is also another factor the manufacturer has to consider.
Same could equally be said for the suspension but, as the average CS user will leap to saying
"Yer, but it's not designed for gangbanging bad boyz lik me, check out dis slammage y0!"
If you want your Clio to sound even more like a tractor, you get that viper in your engine bay fella, any performance difference will be so minor you will never know. In fact, because its louder you'll be convinced its quicker, whatever happens.
On topic - no, no remap needed.
