Need help ! Smoke coming from engine
  16v Clio
Today i was on the motorway when my engine overheated and nearly went on fire =|
The engine overheats and lots of thick smoke comes from the engine.
There is a small valve at the right hand side of the engine block and there is smoke and the water (Anti-Freeze) Spraying out of it .
Any ideas ?
Maybe something has came off of the valve, it looks like there is a screw thread on it .
Ill try get a pic in the light
  16v Clio
thats what i was thinking , looks like somethings to be screwed in to it but nothings there
Any ideas where i could get the part number
Struggler
  Ph1 track 172
sounds like the 'bleed nipple' has fallen off,
never heard that happen before, is it on the side of the thermostate? facing outwards??
have you tinkered with the coolant and anypoint??
dont see any reason this should just pop off,
pop a new one on and make sure its tight
  16v Clio
Its the bit facing outwards on the side of the engine,just where the coolant pipes go in to the engine
  16v Clio
If its that it should be ok to pop on a plastic dust valve . think it should fit
any ideas where i could get one from ?
Haven't read the thread but if its the bleed nut for the cooling system it needs to be metal, Or strong plastic with a good seal not a dust cap :p
  Megane dci 130
Is it a 1.2 16v? They are dust caps as standard on the bleed screws, as are all of the diesels.
  16v Clio
Just got the Rac out in the end
He stuck a dust cap on the bleed screw and the thermostat will need replacin but thats it thank f**k :)
