Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Previously the car was damaged to front left side - found broken subframe (even non sport i gues) and two different wishbones - so some one change wishbone to non cup. So only outer ball joint hole is different between these? if so i think i can just drill new hole.
Is there are difference between ph2 sport 172 and ph2 cup 172 subframes?
I dont think the subframes are different, but I havent personally compared to be 100% sure.
Yes its just the mounting hole that is different on the cup wishbone, so redrill the other one to match the cup one with the balljoint pointing forwards.
