Previously the car was damaged to front left side - found broken subframe (even non sport i gues) and two different wishbones - so some one change wishbone to non cup. So only outer ball joint hole is different between these? if so i think i can just drill new hole.
Is there are difference between ph2 sport 172 and ph2 cup 172 subframes?
I dont think the subframes are different, but I havent personally compared to be 100% sure.
Yes its just the mounting hole that is different on the cup wishbone, so redrill the other one to match the cup one with the balljoint pointing forwards.
