need help with air filter
Car  Clio 1.2 Dynamique
just bought a ripspeed universal air filter for my 1.2 renault clio 1.2 dynamique, i have no idea how to fit it, can someone help me out?
thanks
pull off engine cover and unscrew jubilee clip for airbox and disconnect breather pipe, fit filter where airbox was and put the oil breather on, 2 mins and jobs a gud un
Won't go striaght on if its a Ph2 and probably won't fit straight on even if its a Ph3 with the revised inlets either.
Ph3 so has the revised inlet D4F hence why a universal filter will go. A Ph2 doesn't have a normal throttle body opening you can just drop onto unfortunately.
