Need ure advice! PLEASE!
Car  Clio 1.4 16v Dymanique
Right, ideally what i want to do is, buy an amp, And then run a 12" sub off of it, around a 1000w with a good RMS to match the amp...
And also run a set of component front speakers off of the same amp.
Whats the best way to do this, I've been told to maybe look at buying to amps, one for the sub and one for the front component speakers.. however I would rather just have 1 decent amp powerful enough to do the job..
Im after sound quality with a good bass to it :)
Any help, guidance would be appreciated
Will
No mention of musical preference....
No mention of budget....
Fair sound quality with an emphasise on bass....
Could do worse than;
Front Components
JBL GTO1004 4ch amp
JBL GT5 Ported enclosure exclusive to Motorworld
You would also benefit from deadening the boot area, (cover all panels inc the hatch panel), & deadening/sealing the front doors....By creating a sealed door cavity you will greatly increase mid-bass performance from the front end....
The above is just an idea, for more detailed recommendations more information would be required....
Due to your musical preference I would opt for a Vibe CBR 12 'passive' enclosure, these are much more suited to hard punchy bass lines....
The components & amplifier previously selected would be fine....
Head units are a personal item, you should select one that your happy with on all levels, (sound quality, function/appearance, menu layout, features & price)....
