new additions for RS-1
  RSTUNER'ED-C&B'ED RS-1
Just bought these,
Many thanks to Maurice from MBEngineering, awesome built quality. Not have a chance of fitting them, will be very soon.
Mod list at the mom,
Colombo Bariani cams
k-tec stealth full zorst (+remus backbox)
matched inlets
Fastchip custom remap
Powerflex bushes
Hill Power inlet elbow
parts received waiting for installation
ITG maxogen
short shifter + 15/61 gearbox
megane RS injectors
ARP rod bolts
catcam valve springs
battery replacement kit (splitter and cable off a 530 BMW)
Turbo is not in my league, at least for now. There is incredibly huge customary expenses here so I would not even bother looking at the kits.
Maxogen = Win.
Very fancy bracket with yours too!
Wait for it, this kit is for Pug206 GTI/RC but fully compatible with Clio 172. Even better than Clio 172 specific one since it has a nice polished and colored Al inlet pipe matching the diameter of the Clio's butterfly. I think I am gonna use that bracket while fixing it or at least cable tie it to an appropriate location
  RS RIP
Nice one that short shifter Alper , good choice. Came out best on an independent test above 2 others, one being a genuine Renault sport one i believe !
This one is on my want list too , first up are tyres :( (+ some Speedlines)
  RS RIP
Alper , any luck with fitting the new additions? How do the C&B cams run with the Maxogen on there ?
  182 trackday racer
Have some questions about the megane RS injectors. Did the Fastchip custom remap indicate that the car didnt get enough fuel?
I will install CatCams 428 + catcam valve springs and do a custom map so im a bit curious.
Hi Frank,
Not yet, it is gonna be done in next month. I am busy with my dad's 1.6 16V Clio. Henk is remapping it currently. He certainly knows what he does, we gained % 6-8 over superchip's map with his custom map. He also wiped out the excessive KC. I am very well pleased with the results.
Nope, currently injector duty cycle hits 91 % at around 7200 rpm. It is best to keep it lower 80's % if possible. That's why I bought bigger size injectors. Henk's remap is by far the best.
if you still have not bought cams, I strongly suggest you to buy Colombo&Bariani's. The massive gains are well proven on many CS user's cars including me :)
Ali
  V6, Trackhawk, GTS
It's very nice! Nice touch. I had one of the first generation Maxogens in 2004? Still rate it as the best A/m airbox on the market.
  182 trackday racer
Hmm not realy sure were to buy these. If i take a look at the Fastchip webpage and performance logs I already have the same peak power output as a 172 with the Colombo cams @ 115,7kW and 194Nm.
From RS tuner performance analyze I got:
115,8kW @ 6336rpm 188,6Nm @ 5383 ,drag 26.4 and weight 1200kg
This is on a 182 with stock cams, just mild modifications to inlet and cathlyst. RS tuner generic map and a Milltek exhaust.
  RS RIP
Alper, any luck fitting these yet ? Really interested in how you find the short shifter , ofcourse the Maxogen too
Hi all,
UPDATE !!!!
First of all I should have done these mods before.
Awesome piece of kits both.
Short shifter, now the stick never moves while accelerating, perfect, and while shifting you really feel the gear ways.
ITG Maxogen, nothing new just awesome as known :) Probably the biggest filter element which can fit without any modification in the bay. Very nice light weight casing and also heat insulation. Without saying more word, I am going to collect some data via my RSTUNER and we will see the pressure drop across the rpm range and compare it against the ITG panel. It feels much better at top end. I would not want to mention the roar
  RS RIP
i was going to get the shortshifter a LONG time ago... you've just persuaded me to give Maurice a call .
Was it easy to install ? And did you also fit the clutch-pin (optional) or left it OEM ?
Hi Frank,
Installation is easy, 5th gear is tricky but I am quite sure, any mechanic can easily adjust it.
I did not get clutch pin, OEM one is more than enough.
Alper
