New Battery = No Power?!
Car  RS Meg 175
Hello all,
Grabbed a new battery yesterday due to the old one not holding charge be it through jump starting or charging from the mains, But it started with a mobile power pack attached to it.
I fitted everything as you would expect (just reversing how I dettached the old battery.)
But after fitting I turn the key and there is not even a little bit of power, nothing.
I noticed the clamps that go onto the battery poles were a bit corroded, i thought maybe it could be those?!
I have also read about alternators causing similar problems?
Any help would be greatly appreciated!
You need to start simple so:
  1. Check the battery has voltage.
  2. Check all connections, both +12v and earths are secure and intact.
  3. Check all fuses (Especially the 120A unit in the + battery terminal).
If the above is ALL present and correct you will need to widen your search... normally the above will fix things though.
Mick
