New brakes question?
TeZ
Car  Non RS : (
Well i need new front brakes.
Do i need to change the disks aswell?
Also what are the best ones to get EBC greenstuff etc?
Also where to buy?
Links if you can please
TeZ:star:
If the discs are worn, warped, or poor condition (pitted/grooved) then change them. If not new pads will be fine. Most people don't rate greenstuff's, the uprated ferodo pads have a strong following. Don't know the code, someone will tell you...
Ta, and what Disks??
Any web sites to order from?
for a MK2PH2 1.416v clio (51)
Stock pads are more than enough no need for greenstuff or anyhting seriously stock setup was build for 150hp group N homogonilisation rallying and racing.
Greenstuff etc try Demon Tweeks drop me a message if your going to FCS and want me to pick them up.
As for the disks well there loads of choice stock are fine £60 or so halfrods or similar if you can find someone with a trade card etc.
thanks as usual edde, seems ill just get Stock disks wiht some better pads.
TeZ
TeZ
No need for uprated pads greenstuff are a good pad if you want to have an uprated don't bother with ds though there expenisve.
