New car protection
Car  250
We pick up the other halfs car this weekend (brand new 207CC) and i want to protect the car before its really used.
The car isn't having the dealer diamond brite, so what can i do to keep it protected? Is there something I can coat the alloys with?
Thankyou
p.s - dont mind investing in a few products as I will use these when my new 250 arrives
Hi mate, give her a good strip down with clay + get some good polish,sealant + wax on top. Poorboys wheel sealant is good for wheels.
Thanks Magpie - so i need to clay a new car?
can you recommend which products and where best to buy?
Thankyou
AG Super Resin Polish and Extra Gloss Protection are good products, and you can get them from halfords.
You can also get AG HD wax too, which is very good :)
You should defo clay a new car, it will be covered in god knows what.
As mentioned, SRP and EGP will be great to get you started, i sugest you get familiar with those two first i havent used the pair for the best part of a year, but i will be doing on my dads car next week i hope..... Good results and long lasting protection.
As for clay, get this, its cheap and its good.
http://www.elitecarcare.co.uk/autoclay-soft.php?cPath=79
And for applying the SRP and EGP, i have been using these for 3 years and dont see the point in trying anything else as they work very well.
http://www.cleanyourcar.co.uk/accessories/blue-perl-microfibre-applicator-pads-pkg/2/prod_186.html
Removing the polish and egp....
http://www.cleanyourcar.co.uk/microfibre-cloths/eurow-shag-pile-double-density-towels/prod_436.html
As for your wheels, i would use SRP and EGP again to save a few quid.
Its up to you where you go from there, i assume you already have buckets, washmitts and a good shampoo ?
Oh, enter cliosport in the discount part and get 7.5% off, SRP and EGP available here.
http://www.i4detailing.co.uk/acatalog/Autoglym_Super_Resin_Polish_1.html
http://www.i4detailing.co.uk/acatalog/AG_EGP500_1.html
thanks Cliotoby for that. Brilliant response
So what should I do first - wash, clay, SRP & then EGP?
Thankyou
Thankyou
Yep..you need to use some form of lubricant when you clay though..you can put some shampoo in a spray bottle and use that as lubricant rather then buying something like Meguiars Last Touch.
"IF" you were going to buy the bits from I4detailing personally id go for these applicators..
http://www.i4detailing.co.uk/acatalog/I4D_Detailing_Product_Applictor_Pad_1.html
Saves ordering from 2 sites..although Halfords DID sell similar ones this time last year
Edit oh and you can also get clay from there...personally I have used the orange one and compared to the more exoensive Sonus clay bars I didnt notice any difference really.
http://www.i4detailing.co.uk/acatalog/detailing_clay.html
Wash the car well, clay it, youll need a lubricant to help the clay glide over the paintwork, use an old clean sprayer unless you want to buy one (see the Cleanyourcar website), i use very diluted car shampoo in a spray bottle but you can use proper clay lubricants or some people even use clean water.
Cut the clay into 3 pieces, warm one piece up using warm water, i run mine under a hot tap for a bit so it becomes soft, and mould it into a wafer thing. Then spray some of the diluted shampoo onto the paintwork and onto your clay bar face, all you need to do is rub with a very small amount of pressure back and forth. When the face gets dirty, fold the clay in half and then flatten it out again so it becomes like wafer again. it doesnt have to be mega thin, i keep mine around 10mm thick, not that that matters lol.
Bonded contaminates will be removed from the paintwork. My car is 5 months old, and when i got the car it was covered in what looked like rust and the odd bit of tar. Clay should remove all of this as it did with mine.
It takes time but its worth it.
After claying your car, wash it again. Dry it off. Move the car into a garage if possible.
Go round the car and apply a thin layer of SRP. Apply a small amount onto one of those applicators and rub in a circular motion or go back and forth or whatever you want, as long as the paintwork is covered, do the entire car and then remove using a towel. Dont apply too thickly as it is very dusty. Do not apply in direct sunlight. This is a filler polish, as in the swirl marks you might be able to see will be filled and not corrected, while SRP does contain some micro abrasives, it isnt really good for removing more severe wash damage or paint defects, it will however remove light wash marring, its a fantastic product. Avoid contact with plastics.
Once youve done this get the EGP and apply it to the other applicator, apply in back and forth motions or in straight lines, in an even fassion, and leave it to stand for at least 60 mins. From my experience, the longer you leave it the easier it will be to remove. If i remember correctly, i think the reccomended time on the instructions is 30 mins to 60 mins. I would leave it 60. Get a fresh towel and buff off, it should be fairly easy to remove.
If you want, you can apply a wax over the top of this but by no means is this completely necessary.
What ive told you to go for is from my own personal experience, its a great polish/sealant to use and i highly reccomend it to anyone wanting to spend a bit of time and a little money on their car, i have since moved onto different things and do not touch either of these products anymore, which is a shame in some respects as they are both very good. These products are by no means the best out there either, and different people will give you different advice, but i think from what your after and the budget you have, this would be a great place to start.
What products do you have for washing?
