New Clio Cup
New Clio Cup takes the best of the innovations made to the four cylinder 2.0-litre 16V (F4R RS) engine fitted to New Clio Renaultsport 197. The engine has not been modified internally in any way from the one on the production version. It is sealed at four separate points before being fitted to the car.
Externally the engine differs from the production car with the air box, taken from Clio V6 255. and the mechanical throttle valve unit which replaces the motorised model. The engine and gearbox mountings and specifically-designed.
The exhaust system has also been revised. The ‘3Y' exhaust manifold has been retained, but the intake catalytic converter has been removed leaving only the main catalytic converter in place. New Clio Cup can however, at no extra cost, be fitted with the optional production silencer limiting engine noise to 85dB.
Combined with the optimised electronic engine management, these modifications yield an increased power output of 205hp at 7,300rpm and torque of 223Nm at 5,550rpm.
different air box eh?!
So it's been re-mapped and had some sort of de-cat?
Yep V6 airbox decat of sorts and the manaugament has been adjusted to take account of the fact there less restriction.
I cannot wait to here what tunners can do to this car I recon they'll say 210hp with just a remap even though Renault cannot get them to that and they know what there doing.
