New Clio V6 Mk1 Owner - questions
Hi
Ive just bought Knockers car - picked it up today.
Its fantastic and great fun - Im coming from a 911 GT3 so I suppose they have something in common!
I have 2 questions though -
1) is it normal to smell coolant from time to time? (I used to get this on an Elise I once owned so assume it may be the same)
2) there is a slight whistling noise at certain throttle openings that sounds like the exhaust - is this normal?
thanks for any help
Craig
® Andy
  Illiad V6 255
Reckon mine smells of coolant a bit especially when run hard. No leaks Im aware of and doesnt run hot either.
As for whistling ... lots of whistles/whines so difficult to say if yours in a normal one. Clarkson said it was like having two Hueys in there when the revs rise ... and hes not far wrong :D
Not smelt anything funny (yet) & as Andy says, loads of different noises, so difficult to detect just one whistle. Get a BMC induction kit & decent exhaust. then the only sound you will hear is that glorious V6
Ah.............the exhaust thats why I cant hear anything...............yeah forgot about that.............it does make dif eh Jay (hes heard mine)................you going to FCS?
Cya Stu
[Edited by stusV6 on 23 May 2005 at 7:50pm]
I can hear whistling from the engine in my vee at different throttle openings. Usually at 1/4 to 1/2 throttle. Easiest cure Ive found is to never use less than 3/4 to full throttle! ;)
  Renault Laguna Coupe
The whistling is brilliant - sounds like a Huey warming up its rotors in a Vietnam clearing (Sunday Times I think).
  Clio RS 172 Ph2
I get the whistling in mine, no smell of coolant, but I have had to top it up a couple of times...
Thanks for the help guys
I must use full throttle a bit more often then!
I will check out all the hoses to make sure there are no coolant leaks
Craig
  Evo MR FQ300 & Clio V6
Just check the coolant cap has a rubber seal on the inside. Whistling is very normal. Agree with the induction kit - makes the car sound the way it should. (I have a pipercross on mine).
Enjoy
Simon.
