New Clutch -> what do i need to do to get the shaft leakage sorted ?
Car  MX5 NC 2.0 Sport
Im going to get the clutch replaced on the sunflower.
But which of the gaskets could i get replaced on the gearbox to get over the shaft leakage.
As the box is off anyway i might as well get this sorted if possible :wink:
What can be replaced to sort this without rebuilding the box (gaskets etc. ?)
Are you meaning the common leak from the selector shaft?
Unfortunately I am pretty sure you need to split the box open to fix that, to get to the seals and the small bush(?) that need to be replaced - so may as well rebuild the 'box anyway.
@NorthloopCup would be able to confirm.​
