Tried replacing what I thought was dodgy leads (kindly supplied by Adam) but it is still not firing on one cylinder. Could the coil be faulty or would that just not fire at all?
depending on the ecu/coil setup typically DIS ignition will ignite 2x2 (i think the 2&3 then 1&4 depending on the engine) So if it was a coil pack fault, or wiring loom to the coil pack, or the ecu damaged by a bad coilpack or loom.. it would miss on 2 cylinders, not 1.
Right done that and i'm getting a spark on all four leads at the coil end and one hell of a belt myself ha ha! So they can only leave plugs or injectors right? Wow i'm buzzing now
Ok so its cylinder three that's not firing ie no change when injector unplugged so am I right in thinking its either a spark plug or injector fault? Swap a plug over then I suppose
