new little mod
Car  b/g 182, meg tourer
see if you can spot the new modification?
i know... i might not pass my mot. but i think i will and it only takes half an hour to get back to normal. i was sick of leaking valves and trying really hard for them not to spray on my (when it was clean), so annoying when its clean and then the headlamp washers spray all over the car and leave big streaky water marks :mad:.
problem solved. cots me £1.49 for a pack of assorted blanking grommets from halfords. better than £70 renault joke prices!
also smooths the front end off nicely. suits a black car.
Going to do the same myself this weekend. What did you do with the pipes, just blank them off?
Why not just pull the hose off the back!? :S Thats what i've done!!!
well... i also didn't really like the look of the washer jets. imo the look better smoothed off with rubber blanking grommets. it was an r27r that gave me the idea.
removing the hoses would be a quick fix tho.
i pulled the pipework out. there are 2 straight connectors inside the passanger wheel arch, i just capped them off there and unclipped the pipework from the bumper and removed the jets.
Tidy job but mine have no problems at all :)
Does the washer bottle still pump water out to the pipes (where the pipes would be) when you wash your windscreen with the lights on?
