Jekyll
I'm looking at working on the bg over Christmas and ill be doing the following:
Oil change
Coolant change
General clean up
Ill be buying oem oil filter and washer and I already have some elf evolution sxr 5w40. Having a read on here ive seen the recommended coolant is renault type d. I was also contemplating getting a new expansion bottle as mine is rather manky.
Is it a case of undoing the lower rad pipe and bottle and letting all the fluid out and refitting and putting the new fluid in or is there more to it than that?
I might change the power steering fluid too. Can I undo the pipes and remove the bottle, clean it and put new fluid in or is there more to it than that also? And what is recommended for decent power steering fluid?
Lastly can anybody recommend a decent engine degreaser/cleaner?
Thanks, Mark.
Oil change
Coolant change
General clean up
Thanks, Mark.
