New oil pressure sensor - Williams/16V
I cant find anything about this in my Haynes manual! (just something about the gauges)
Can I do it myself and how much is the part? Or should I just get my garage to do it when I get it serviced soon?
ive been lookin at gettin a new 1 for bout yr dont know where it even is jus know/think its below the inlet manifold
its the sender on the front of the block under the inlet manifold.
just put your hand down along the side of the alt and you can just see it through the gap between rad and alt. It should had a white clip on the connector plug IIRC.
the actual oil pressure sensor is located on the rear of the block. if fits into the top of the auxialary shaft drive(i.e. oil pump drive). its very difficult to get access to it on the 19, mite be easier on the clio williams. ul need a 17-18mm spanner to undo it. the low oil pressure sensor is located on the front of the block, to the left of the oil filter.
jimbo
  Skoda Fabia vRS
you will be able to gt this sensor from your local Motor World
if you want i could try and get you a price tomorrow for it....
could you get a price 4 me pls brun? take it the 16v and wlliams have same sensor? do you think im capable of fittin it? i can do simple tasks
  Skoda Fabia vRS
should be no more than £10 mate from your local Motor World
i checked today for you
thats an InterMotor part.........cant remember the part number off the top of my head
markld yeah i did mate but no offence i ickle stupid and thought if get 10 different peoples way to fit it.... i startin to understand it now tho :) the back of the engine is that exhust manifold side?
  Ph1 172, Mini 2.0l T
myky16
Yeah back of the engine is exhaust manifold side, it sits adjacent to the brake servo.
