Octavia vRS tfsi
Fitted Pagid Blues to the front of my ph1 RS about a forthnight ago. Haven't driven the car much since then. Put them through the Pagid recommended bedding proceedure and some driving since, nothing too hard.
There seems to a howling noise (for want of a better word to describe it) coming from the front left intermittantly, that immediately disappears when I touch the brake pedal. Ultimately, I have put this down to a sticking pad and tonight they're set to come out, be given a slight rub top and bottom and refit again.
Why is this only after happening on the left and not on the front? Are there other causes of the symtoms above? Not enough copper grease perhaps?
What effect would the springs on the back of the pad being bent either too far in or two far out have?
Looking for all opinions before I go sanding and filing slight bits of pad that once they're off, can't be replaced.
