Nightmare with Engine cover bolts
  Arctic 182 FF
Hi guys
Basically I found that one of the bolts has lost its teeth on the head. Just spent the past 30 mins trying allsorts but to no avail. Currently got T30 torx bit superglued into the hole waiting for it to set to see if that works
If not I guess its cut the cover from the front to as close as to the bolt as possible, undo the other 3 bolts and try to yank it of so I can get a pair of plyers to the bolt?
Or is there a better way of doing it?
