NIGHTMARE !!!!
  Mk2 1.4 s
im trying to remove the back seats on my ph1 as im changeing the interior the seats are bolted to the floor useing 2 torques heads there stuck tight and the heads are now semi rung anyone got any ideas as to how i can remove these
You could, but you might damage the threads and not be able to get the new bolts back in. Or just roll without, like me :cool:
No it's still on as far as I know. It's been like this since I bought the car... just not attatched!
  RS6 C7
Ahh those bolts!
Iv'e had a nightmare with every clio iv'e tried to remove them from!
You will get them out with mole grips and some swearing ;)
  Mk2 1.4 s
Ahh those bolts!
haha tryed the swearing already the wee f***ers just sat it there holes and laughed at me struggleing
  K4M ph2
Get under the car and attack the underside of the bolts with a wire brush and a load of wd40 works a treat!
JezzaMac
I had a good battle with one of these one night. Like said above, clean the threads on the bottom of the car best you can. I then wrapped a fair amount of masking tape round the edge of the bolt and smashed a socket on. Think I cut as much of the bottom of the bolt off as I could and then replaced it with a proper hex head bolt.
  172 Cup & K20 Ph1
I had a nightmare with these too, ended up using a lot of WD40 and screwing and unscrewing until it came loose. As others have said, if they are rounded consider drilling and using a reverse thread screw so you can still remove it with the threads intact.
