No Air Blows - Advice/past experience required!!
Car  Clio 172
When I turn the heating/ aircon / air circulator on no air blows out at all but all of the lights appear as normal just no air what so ever. I have checked the fuses and they are all intact. I have read up that the resistor pack may be the issue but it seems people who changed this part had a small amount of air blowing through, i have none what so ever. Not sure what to do, any ideas or things to check people would be a great help!!!!
thanks in advanced!!!
Will be the resistor pack. Some people report blower stays on full others low and most nothing at all. Find someone with one that works and swap over to check. 10 min job to switch and make sure before spending ££ on a replacement.
thanks for your response Mark, very much appreciated.
can any resistor pack be used on a 2002 172 phase 2? basically if I found a resistor pack on a 2002 clio 1.2 in a scrap yard could i use that or does it have to be matched the same spec car?
