No bolts with Recaro mounts? Trendlines
Hi All,
Just had my recaro mounts delivered from Captial Seating to fit trendlines, but there was no bolts supplied with the frames?
Can anyone confirm if bolts should be supplied (From looks of instructions they should be), and in either case, what bolts are needed to fit them?
Cheers,
T
@optical Was about £330 all in from Capital Seating I believe with the CS discount.
Then you just need 8 M8 x 16mm High tensile capped allen bolts to fix the frames to the seat, everything else is reused – Bolts were about £2!
Word of warning – The threads on the factory rails are easy that you would expect to cross-thread or strip, especially with the awkward angle if you don't have the car on a proper ramp.
