no washer jets working after gearbox change
Car  Clio 182 ff
No washers jets are working after changing gearbox with no noise from the motors. They were all working fine before. Has anybody had this before of can put me in the right direction. Thanks :disrelieved:
Checked all fuses none are blown. I thought I might have disturbed something when fitting the gearbox. Where does the harness connect to the other side to both pumps?
Bottle and pumps are in the scuttle panel so don't think you would have damaged them. Check the wiring around the gearbox for damage then it will be out with the meter to fault find.
