noise from rear of car
  Clio 4 :) 306GTI-6
so i did a few searches and i think i know whats wrong but as im new to renault i thought id ask as i dont want to spend to much money incase its not the issue lol
from the rear of my car there is a creaking/rattle. i thought it was exhaust as thats the kinda noise it makes (i still think its part of it) however last night i pushed down a little on the rear of the boot and the car went down, it didnt bounce and it creaked something awful. im pretty convinced this is the noise im hearing when i drive. is this the shocks?
car just passed a year mot on 30th Jan with an advisory on play in the front steering rack joint, no mention of the shocks.
next question if it is the shocks should i just buy coilovers as i wanted to lower it anyway
George@RTR_Parts
ClioSport Trader
The exhaust knocking could be the rear exhaust mount, it has like a star of rubber in the middle that perishes so the hanger rattles around in the square of the mount
Sounds like you have a leaking rear shock. Have a look under car and both these should be fairly obvious.
Depends on budget regarding Coilovers. You can get a set of lowering springs and use them with the existing/new Renault shocks. The shocks are around £45 each and I tend to replace them in pairs. Lowering springs, from either Eibach or Cooskport on here are around £130
Hope this helps
  Clio 4 :) 306GTI-6
hey G 172
thats a great help :) i probably dont want to spend more than the £200 so will go with the option of new shocks and lowering springs. I only plan to lower 40mm tops so dont think i will have a need for uprated shocks etc but if i was able to buy coilovers for not much more than £200 then id have done that option. I wont be using her on track, she will just be for occasional use, so want something comfortable to drive. With the exhaust i take it i can just buy a rubber yeah
George@RTR_Parts
ClioSport Trader
No worries
You would be better getting new genuine shocks and a decent set of lowering springs then a budget set of Coilovers for that kind of money tbh
You can buy the rear mount separately and come with the rubber insert in. Some people modify them by using cable ties and nuts/off cuts of silicone in the mount to reinforce them. They're are designed not to be solid though
  Clio 4 :) 306GTI-6
ah ok, i wouldnt modify it id end up making it worse. The car has a powerflow exhaust with a lifetime guarantee. i assume the mount is on the car and not the exhaust
  Clio 4 :) 306GTI-6
excellent as soon as the snow decides to bugger off i shall have a wee look and see
