Lately the engine (1.6 16v k4m) has developed a less than perfect idle, the speed is ok, between 750 and 800rpm with no aircon and a bit higher with the aircon engaged...changed all coil packs, new plugs, cleaned the tb, cleaned the CAS....nothing, the engine has slight misfire that is noticeable only without the aircon running...but yesterday I heard the idle speed valve (Magnetti Marelli one) make a rattling noise, disconnected it with the engine running and the noise stopped (and the idle didn't change a bit). The engine never stalls or idles high so I suppose the valve is working fine...but do they all make this rattling noise?
