Non Starter :(
  182/RS2/ Turbo/Mk1
Update. Seems to be confirmed as electrical. I put it in 3rd and rocked it and the aux belt has moved.
The garage can't pick it up until Monday, so I'll just have to wait. It's sat on the drive looking sorry for itself!
Jack it up, and put power to the solenoid mate and see if it turns over then.
If so then you know that when you turn the key its not getting power to the solenoid.
So then you can work back from there, its quite probably the wire from the relay to the solenoid rotted, especially if you have run without arch liners (because racecar)
Get a bit of cable, clip one end to the live going to the motor then use your new live to trigger the motor. If it spins then you have a trigger cable issue
Cub.
Cheers bud, I'll give that a whirl this weekend. Stuck in meetings for the next two days. At least it's not the engine! :)
  182/RS2/ Turbo/Mk1
Might be mate.
The block might have rusted away so much it no longer conducts electricity.
Cub.
Might be mate.
It conducted electricity to fire when Dan tested it. So it's not that.
I had to jump it to get it to start to put it in the garage in the first place before the engine swap. I thought it was the battery at the time, although now I am not so sure...
  182/RS2/ Turbo/Mk1
LOL, was a joke mate!
No block ever does that!
To me it sounds like earths still.
Go to halfords and buy a couple, and do like I said on the phone,
Battery -> chassis
Battery -> engine
Chassis -> engine
Try starting it, if it still doesnt fire then do what I said about positive to the solenoid.
Dr HMS Derv Destroyer
  MK1DCi/vivaro/REN’11
Dreads heap of s**t did this. Wouldn't turn over
so we swapped starter, still nothing , jumped it off my dci, if fired up but if we tried firing it up without my dci helping, then again nothing.
Battery was checked/ fuse box in engine bay in pieces - corrosion on everything
eventually we gave up and Fred got it going I think ( can't remember if Dave tried a new battery or not )
I'd be cleaning all the fuses and relays up in the engine bay box, including the big white multi plug at the bottom of it ( clean them properly so they look like brass almost, then put some Vaseline on the pins
That box stopped my ecu working , which pissed me off trying to find the problem
Cub.
Battery -> chassis
Battery -> engine
Chassis -> engine
Lol! You confuse me good sir!
Stand by your beds on Saturday then chaps (or your phones....) :)
Cub.
We tried to fire it off Mikes DCi. Nothing. Not even a splutter. I'll start with chips tests, then start cleaning stuff up. I don't run arch liners (looking for a pair) so he may be onto a winner with the relay to the solenoid.
Yeah try chips test !
Im almost certain it's either that box of crap or like chip said, something rotted , loom wise IMO
  Many.
If anybody else comes across this thread in the future, check the earth by the headlight (Where the battery earths onto the bodyshell), It was heavily corroded as per normal, cleaned up and it turned over, then it was just the fuel pump relay that needed cleaning up in the engine bay fuse box.
Easy fix!
Cub.
Easy fix!
Easy fix if the person you are helping doesn't lock himself out of his house, and have a broken bonnet catch which means we couldn't get into the car. :)
Really appreciate your help bud, good to meet.
