Not starting now...
Sib
  Clio 172 (Silver)
About 30 mins ago I changed my steering wheel, all the trimmings, battery off, airbag off, wheel off, however when reconnected the horn contacts didn't match, the airbag light came on and then the cable which coils around snapped.
The car still started at this point and I stripped it all back down to get at the damaged component and have taken it out, however - now the car won't start. I've locked and unlocked it a few times, it just turns over 5 times then stops.
Any ideas, is there a kill switch or have I done something daft like lost the key code.
Also how much is that part to replace. Its the airbag flat coiled wire thing.
Whats the immobiliser light doing?
Did you disconnect the ring decoder (bit round the barrel) when you took the wheel off?
