odd wiring fault, fuel pump and speedo
Adey.
bit of an odd one, hope someone can shed some light on it for me.
today hooning down the quarter the car lost all power, first thought was thisis bad tho engine was dragging down as if the throttle was closed, it was wide open to. any way checked the usuals, cambelt first then a few sensors, tdc off and cleaned tho its allready a newer renault item, had spark so checked for fuel. couldnt hear the pump priming so pulled the lines off and checked, no fuel. round to the boot and pulled off the fuel pump wiring to check it all, no voltage getting to it??? swapped around all the relays in the bay thinking it was one of them as ive had that fault before, fixed by slapping in some new ones, but nothing. was getting on in the day so ran a wire with a switch in it to the fuel pump to get it to run, does so perfectly now but obviously hasnt fixed the fault? also the speedo went out and has not worked since so think these may be connected, well they have to be as it stopped working as the fuel pump did. any ideas?
