OEM vs Purflux retail oil filter
PerthRS
  Clio 182 CUP
G'day squad,
Was just doing some browsing online on clio miscellaneous things.
Found out that the OEM oil filter manufacturer (Purflux) also sells a retail version that isn't renault branded or packaged for the clio 2.
OEM part number: 8200768913
Purflux part number: LS932
They seem to be exactly the same from what I can tell. Just without the aforementioned Renault branding or packaging.
Has anyone dealt with/used the LS932 before?
As for me its much easier to source then getting a 'Renault' one sent over to Aus or going through a stealership (dealership).
Attached are images for your reference.
PerthRS
  Clio 182 CUP
Thanks guys!
As OEM ones are a little steep (especially locally) this definetly is a better alternative if they are the same.
R3k1355
I wouldn't be surprised if they have/had multiple OE suppliers for things like the oil filter.
Jamie86
  RS175,595,205gti,172
Someone did cut a few apart once to compare them all Mick maybe? Do a search and should pop up 👍
PerthRS
  Clio 182 CUP
This is a sample image from Fred. That now lives in Australia.
Left to right
Genuine Renault/Purflux, Ryco (Z608), Repco (local retail automotive brand. Equivilant to your Halfords).
Can see that the genuine has significantly more surface area. With the anti-drainback valve also being over better quality and the base plate being much thicker.
  02 Iceberg 172
Left to right
Ryco - the clue is in the name lol (Ripping You C*nts Off). The most overpriced and poor quality stuff around. Plenty of better and cheaper options.
