Mark 2 Phase 2 182
AKA
182
Mark 2 Phase 3 182
You will often see 182 referred to as 'Full Fat' or 'FF' for short. These versions of the standard 182 also come with 'Cup Packs' these are the Cup suspension (Firmer, lower suspension and anthracite alloy wheels) and the Cup spoilers (Slightly larger rear spoiler and front splitter).
Mark 2 Phase 2 182 Cup
AKA
Mark 2 Phase 3 182 Cup
182 Cup
The 182 cup is effectively "poverty spec" it will have cloth seats, no cruise control or climate control, where as the fullfat will have all of the above but will have cup suspension and spoilers pack.
I knew i would end up confusing you.
The 182 comes as standard with Xenons / Climate, Nice seat etc. You could then spec one or both of the Cup Packs. Making is a 182 with Cup packs.
Later, the 182 Cup was realised, which had the Cup Packs as standard, but also lacked teh Xenons, Climate, etc as it was billed as being more - Driver than comfort focused.
Have a look here mate..
http://www.cliosport.net/forum/showthread.php?562600-172-182-Guide.-Cup-Packs-Spec-Info
As long as you never call your car a cliosport then you'll get along fine![]()
I cant look as im not a member yet
Huh, dont get it lol!
Performance, nothing. Not actually joking either. A member (with a 182) and I went from about 40 to way past the limit and we were literally neck and neck.
The model is a "Renaultsport Clio 1*2", not a "Cliosport" - that's what he means!
As above yeah, a clio sport is a 1.4 mk2 ph1, a Renault Sport Clio is any of the 2.0 16v models.
The 182 is no faster. I am 100% sure of this.
Put the punto on swapz mate someone might want to swap for a 182 or 172
Welcome by the way![]()
Ahhhh. Its just 172 are so much cheaper. I may start looking at them, but it wont have the cup packs.
Of course, there are two phases of 172. The original (phase 1 if you like) and the phase 2 (with the larger headlights, slatted grills etc.).
As for Cup packs and not, it's really only the front splitter you want on the phase 2! I can hardly tell the difference between the Cup and non-Cup rear spoiler.
If you're on a budget, stick with a 172.
I ment i dont want a 172 cup but want the suspension.
Is the cup suspension make much difference, apart from it being firm and slightly lower iirc.
