Oil and STOP red warning light appears
  BG182 FF
If I turn corners or rev to high my red oil and stop light comes on for a few seconds and disappears...what is causing this? Where is this oil sensor located and how easy is it to change if that is the problem. The dipstick appears fine.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
This warning is not automatically an oil level issue. It is a generic warning and is also used to warn you of low oil pressure so don't assume that just because you have an okay oil level that the level sensor IS the problem.
Ideally you will check the oil level and then have the oil pressure mechanically measured at idle and high rpm
Mick
