Renault Clio 172 16v
Just to let people know I did a oil change and rear pad and disc / bearing change over the weekend. The oil change took me about 30 - 45 minutes, and was a piece of p**s. I also changed the rear discs/bearing and pads and this was also a very easy job, I literally undo the 30mm hub nut and the discs just pulled off. I will post pics up later, this may help with other people doing there rear disc/bearing and pads.
I got the full disc/bearing (already pressed in) with abs ring from brake international for £37 + vat and they look really good quality. This is a hell of a lot cheaper than renault. Again I'll post pics up so you can have a look, I also got some bendix rear pads of ebay for £9 (bargain), so its cost me just under a £100 for all the rear disc/bearing and pads.
Darren
Darren
