Oil Cooler info
Car  Trophy Turbo :)
Mocal Oil cooler with a theromstatical Control.
i know how to fit this thats not a issue it was the oil sid eof things i wonderd what too do, i assume the cooler will open up at a certain degrees and let oil via the cooler, Thing is i know ill have to top the oil up also, but what do i do get the car to the temp the stat openes then fill the oil???
What is the temp the stat opens
Andy
it'll probably be around 90-100degC at a guess, techically you should prime the cooler first if you can ( bit of a pain in the arse to do if its mounted the with the inlet/outlet facing down)
fill the cooler with oil first
then i connected one side of the lines up to plate, then poured some oil down the other line before connecting
then run up to temp, cool down ect and top up as nessacery
thats what i done any way
make sure you do the connectors up tight as its a tight space to try re tighten things ect
Pretty sure the inbuilt thermostat on the mocal sandwich plate opens at 80degC:)
the stock stat in a mocal plate is 80 degrees. I replaced it with a 100degree one on my 200sx as I had a pretty large cooler and didn't want to stop the oil warming properly.
You'll always get oil flow into the cooler, it's just a restriction that stops over cooling. The stat is never completely closed.
