oIL LEAK- HOW MUCH?
Because that holds the cams in undo it and tension of the belt could pull the cams out, renault manual says you need to do cambelt as well
yep, to get the rocker cover off you have to remove the VVT pulley, the cambelt etc etc
about a 7hour job
in terms of money what am i looking at to pay for it a rough guide line price, i've seen other members here getting this work done.
Can anyone tell me a rough price for this?
i paid 375 with a service, and cable throttle replacing (supplied my own bits) at my local renault specialist, that was for the cam seal replacing, to fix an oil leak where the oil was collecting under the rocker cover inb the recess's
Damn people, thats an expensive job! I know it involves a lot of work but thats alot of money to be paying for.
Just out of interest where is your local Renault specialist? I live in Newcastle and no way am I ever taking my 182 to the monkeys at Holdcrofts again!!
What ever you do, dont ever take it to place called mendal motors, renualt specialists in the north east. Thats where the previous owner got is timing belt done, and they did a bad job of it, hence the reasons why i'm having problems now.
is it defo the rocker cover or the oil vapour breather casting on the top of the rocker cover?
I also have similar leak, lots of oil that runs down the back.
and dripping on the exhaust manifold. not sure whats the source, I cant see properly..
